need help finding my first gaming/ streaming pc
bot
bot
31 May 2021
United Kingdom
Hi guys, I'm new to the pc gaming community and want to build or buy my first gaming pc which could stream as well. I'm a pretty broke student so I can only spend around like £1300 or less on it. I wanna be able to play new games (like gtav or cod etc) and stream at 1080p if that's even possible. Also I realise that GPUs are near impossible to find so I might have to cross building my own, any suggestions would greatly help.
I wouldn't go anywhere near that. It has a horrible motherboard and psu, and the gpu is pretty weak. No way it is worth £1150.
I thought the same, I figured I'd need an RTX gpu pc of some sort so that I wouldn't have to upgrade immediately. Do you reckon its possible for around £1300-1400 (for the pc only, not including moniter +keyboard etc)
Install windows yourself and get Overclockers to put a quality psu in like a corsair rm.
CODE My basket at Overclockers UK:
  • 1 x OcUK Gaming Pyrite Gaming PC - Intel Core i5 10400F, Nvidia RTX 3070 Gaming PC = £1,383.02
    • Operating System:Unwanted
    • Security Software:**Special Offer** Bullguard Internet Security - Anti-Virus and Security - 1 Year 3 PC
    • Primary Solid State Drive:WD Blue SN550 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)
    • Secondary 2.5" Solid State Drive :Unwanted
    • Memory:Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Cooler Upgrade:Jonsbo CR-1400 92mm ARGB CPU Cooler - Black
    • Graphics Card:*Build Stock* Gigabyte GeForce RTX 3070 Gaming OC 8GB GDDR6 Graphics Card
Total: £1,397.12 (includes shipping: £14.10)
My suggestion comes with the Fractal Design Meshify Case you can knock £ 40 off if you choose the Kolink case.
The GTX 1660 is better than my RX 580 and games will fly at 1080p, my suggested build comes with a Windows 10 license too.
