Need help for building spec
10 Dec 2009
Hampshire
Hi guys i'm looking for a pc for editing, recording (uncompressed HD), streaming and gaming.
not needed OS, Mouse, Keyboard
my budget is £1000 or do you think i neeed more?
Thankyou!
That should suit your need's just fine.
2600K for hyperthreading which will shine with video editing.
60gb 3rd gen SSD
6950 2GB for all your gaming need's
Top quality PSU which will allow you to go crossfire
Plus all the case and internal componants are black so should make a sweet looking rig :)
This is what you want:)
• Retail CPU has a full 3year warranty/packaging and a stock cooler which will be good for re-sale
• Faster more reliable Crucial M4 SSD + bigger HDD
• 16GB of fast RAM with better timings.
The game programmers have said that a pair of GTX580's (£650) is needed for ultra settings.
cool,
will it be able to run it well?
whats the difference between the one you selected and may ones called flex it just noticed
theres a turbo and fan one two. is that one you selected best for me?
Yes, either,
The whole order is delayed until its all in stock and is then sent to you.
Or you get all of it with the cooler to follow when in stock, you get a heatsink with the Retail CPU so no drama.
You won't be any worse of getting it that's for sure, but if you want it that much then by all means go for the 2700k instead. I however would rather put that extra £30 towards a better/nicer case.
