Hopefully someone on here will be able to identify this light bulb for me
The flat I live in has wall mounted light fittings with this particular type of bulb.
Now they have all now blown, there are 6 in total, plus I want to be able to replace them with energy saving bulbs if possible.
And on the topic of light bulbs are there any online shops that are highly rated?
Here is the picture
Thank you.
Edit - Just a little extra information, both ends of the bulb have a concave metal contact point also.
The flat I live in has wall mounted light fittings with this particular type of bulb.Now they have all now blown, there are 6 in total, plus I want to be able to replace them with energy saving bulbs if possible.
Here is the picture
Thank you.
the Halogen ones may be what I need then.
