9 Feb 2012 at 22:03 #61 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Surveyor said: I'm very happy for it. It should be able to better than "something like" then. Click to expand... I only went and had a quick check
9 Feb 2012 at 22:17 #62 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 stulid said: I only went and had a quick check Click to expand... Ah well, I wouldn't want you to go to any trouble.
9 Feb 2012 at 22:26 #63 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Surveyor said: Ah well, I wouldn't want you to go to any trouble. Click to expand... Thanks, only had a quick glance like I said to make sure I wasnt seeing things
