Need Help Please
7 Jan 2004
London uk
Hi
I have replaced my raptor with a samsung F1 750gb which i am running xp home on.My other hard drive is a samsung F1 1TB which i am running Vista 64 bit on.My problem is in the boot up screen it use to give me the option to boot in vista or to boot in xp, since changing the raptor to the samsung it will not give me that option and boots in the vista drive, booth drives are working ok,any ideas how i get the option back when i boot up:confused:
Just in case anyone has this problem i solved it by making the hard drive which run's xp the first HD boot device and then it gives you the option to boot from xp or vista.If i leave it that the vista HD is the first boot HD then it will not give you the option.:D
