[Need help] Setting up SSD & HDD
7 May 2011
N.Ireland
Hey guys.
I need help setting up my 3 hard drives.
I have One M4 Crucial 128GB SSD and two Samsung SpinPoint F3 1TB.
I've had my system for a while and this has been bothering me.
I have all main programs and OS on the SSD and everything else on the HDDs but when I do tasks like empty recycle bin I can hear one of my HDD start to spin up (thats the only way i can describe it)
I am Curious, Does it should like My Hard drives are set up right ?
I simply plugged them in and that was it. I've looked up setting master and slave but I always find videos and forum posts about a little spacer on the pins which I do not have.
I'm still learning, any info would be great, thanks
Change how long it takes for your drives to power down in windows power settings. Although I think some drives spin down on their own regaurdless.
That's under Control Panel\Hardware and Sound\Power Options correct ?
trickynickyuk said:
my f3 spins down when inactive all the time its normal
Hopefully lol. It bothers me sometimes, but if its normal then It wont annoying me too much.
same here its normal for hdd to power down when not used to save power,soon as you access something on it it takes a few seconds followed by a whine n a click sound,as it spins into action
you can make some changes in power settings via Power Options......Change Plan Settings........Change Advanced Power Settings :)
Found it, Thanks ^^
Set it to 60 minutes. See how that goes
That's exactly what happens. Wasn't sure it is was normal.
