Need help with choosing the right parts.
OP
20 Nov 2012
Scotland
YOUR BASKET
1 x Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £431.99
2 x KFA2 GeForce GTX 670 EX OC 4096MB GDDR5 PCI-Express Graphics Card with FREE Borderlands 2 & Assassin's Creed III PC Games £359.99 (£719.98)
1 x Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard £334.99
1 x Corsair AX1200i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020008-UK) £264.98
1 x Corsair Obsidian 800D (6GB/s) Full Tower Case - Black - with FREE Corsair Dual Pack AF120 Performance Fans £229.99
1 x Corsair Force GT 240GB 2.5" SATA 6Gb/s Solid State Hard Drive (CSSD-F240GBGT-BK) £179.99
3 x IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black £125.99 (£377.97)
1 x Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-04649) £119.99
1 x Razer Blackwidow Ultimate 2013 Elite Mechanical Keyboard £119.99
1 x Corsair Vengeance 2000 Wireless 7.1 Professional Gaming Headset £114.98
1 x Razer Mamba 2012 4G 6400 DPI Wireless Mouse £114.98
1 x Corsair Vengeance RED 16GB (4x4GB) DDR3 PC3-17100C11 2133MHz Dual/Quad Channel Kit (CMZ16GX3M4X2133C11R) £99.95
1 x Logitech C910 HD 1080p Pro 10 Megapixel Webcam £79.99
2 x Aqua Computer AquagraFX - GTX 670 Water Block £76.99 (£153.98)
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) £74.99
1 x Hardware Labs Black ICE Radiator SR1 360 £69.98
1 x Aqua Computer Cuplex Kryos XT - Socket 2011 £69.98
1 x LG CH10LS28 BD-ROM 10x BluRay ROM / DVDRW SATA-II Optical Drive - Black (Retail) £52.99
1 x XSPC Acrylic Dual 5.25" Reservoir for Laing D5 £49.99
1 x EK CoolStream Radiator XT 240 (120.2) £38.99
1 x Mayhems Ice Dragon Nano Fluid 1L £23.99
2 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) UV-Reactive Orange 3.3m £10.88 (£21.76)
1 x Mayhems Biocide 10ml With PH Testing Kit £5.99
1 x Official Overclockers UK Elite Gaming Mug £4.99
16 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£47.84)
Total : £3,844.70 (includes shipping : £32.90).
How is this looking? I am planning to run 3 monitors, should I keep the 4Gig cards, or just go for 3 2 gig?
18 Jan 2011
South London
Water hardware wise you should now have everything. Just add some fans for your rads, flavour of the month are usually the Scythe GTs but the new Corsair SP120s are VERY tasty - pick the ones you think look the nicest imo. You may also consider using a fan controller (Bitfenix Recon would do; good, cheap and looks nice).
When picking cards that will fit full cover blocks use this: http://www.coolingconfigurator.com/step1
18 Jan 2011
South London
Go with 2 x 2GB cards imo, adding a 3rd just means more watercooling hardware needed. As I say, 4GB will be plenty for 5760*1080 and it's the clock speeds that'll make the big differences.
OP
20 Nov 2012
Scotland
You know the 670 FTW? I really would've gone for that if it was 4GB, I will be playing everything Ultra, at 5760*1080 and I still want to be getting full frames, how can I acheive this with 2GB cards?
OP
20 Nov 2012
Scotland
Here's an update! YOUR BASKET
1 x EK CoolStream Radiator XT 360 (120.3) £48.98
5 x Corsair SP120 Performance Series High Pressure - Single Pack £13.99 (£69.95)
Total : £3,893.66 (includes shipping : £32.90).
I might not even cool the graphics cards, if that's what I have to do...
18 Jan 2011
South London
4GB (2x2GB) should be more than enough memory to run at that resolution. As I said it's higher clock speeds that'll give you the increases in FPS without going for a card with more shaders.
Gonna say it again cos I need to go sleep. Slow down a bit mate and before you order anything get on the phone to OcUK, you'll not only get sound advice from the forums but you'll get that from the staff there too; one of few decent companies out there that'll dish out honest advice and won't try and sell you what you don't need.
Also, just clicked on your profile and are you actually 12? I'm thinking that must be a mistake, seems a lot of PC for a 12 year old. ;)
24 Aug 2009
Are you good at modding? You have to mod the bottom of the 800d to fit a 240 radiator down there.
I do highly recommend you research everything as you seem to update your shopping list like they are toys. Slow it down buddy :) There is a sticky up on the top of this part of forum, have a look!
If you ain't good at modding, get your self a NZXT switch 810 case. You can fit a 360 rad at top and a 240 rad at the bottom without needing to mod anything.
Also, XSPC RX 360 watercooling kit is a brilliant piece of equipment.
10 Nov 2011
Rugeley
in sli u only get the memory from 1 card not both added together
