Hello,
I would need your help for my first waterloop. I would be in a evolv x case.
I have right now a 9900k and a 1080ti.
I am planning to do my water loop in step : first the 9900k only with one rad.
Than when I change the 1080ti (with a 3080ti ?? ), I would put the new GPU in the loop and add an second radiator.
I am hesitating between 280 +420 or 360 + 360 radiator.
1) I am all about quiet, which one would be quieter ?
2) If I go for the 280 top + 420 front setup, should I put the 9900k with the 280 top or the 420 front ? I read that putting a front rad as intake could make my GPU hotter (until I put the new GPU in the loop). How bad is it ?
Thanks in advance for your help
but the fans. So it's about buying fans that match the rads and generally, a 140mm fan moves more air for less noise than a 120mm fan. 2) if you plan on having two rads, do them now and then add the GPU to the existing loop. As for a front rad increasing internal case temps, yes, it will slightly but no more than having an air-cooled CPU.
