Need help with professional setup - specing
4 Oct 2004
Hi there, I need some help with what i should get. Basicly i what i need is:
1) 100% stability and 0% system lag
2) Very fast access times (so raptor hdds in raid?)
3) Ability to connect atleast 4 monitors
4) 1 storage HDD
5) able to work with windows xp or 2k
6) low noise (just forgot this)
Also i would prefere a motherboard with dual lan ports.
The computer is to be use for day trading - e.g. forex (currency exchange)
I need the graphics cards to be able to draw 2d images extremely fast e.g. graphs.
I have a maximum of £1800 to spend. Can anyone suggest anything?
can someone tell me what they think of this, and if it will work:
Belkin 1000VA Universal Series UPS
Microsoft Natural Ergonomic Keyboard 4000
Microsoft Intellimouse Explorer 3.0 - Retail
3xOcUK Gamer Extreme 178GP 17" LCD Monitor - Black
2x BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail
Asus P5WDG2-WS Professional Intel 975X (Socket LGA775) PCI-Express DDR2 Motherboard
Intel Pentium 4 945 Dual Core "LGA775 Presler" 3.4GHz (800FSB) - Retail (CP-132-IN)
Antec P180 Advanced Super Midi Tower Case - No PSU (Black)
OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
2x Western Digital Raptor 36GB WD360ADFD 10,000RPM SATA 16MB Cache - OEM
Samsung SH-S182D 18x18 DVD±RW ReWriter (Black) - OEM
Zalman CNPS9500-AT Aero Flower (Socket 775) CPU Cooler
2x Akasa SATA-2 45cm Silver Data Cable
Tagan TG500-U25 500W ATX2.0 Dual Engine Silent SLi Compliant Silent PSU
Those gfx are too powerful, a 7300 will suffice, with the money you save there get a c2d instead.
Bear in mind that with raid on your hdds theres double the chance of your data going pop
Also what about the ram on my list, does that seem suitable? Im not too sure how ram matchs to cpu/mobo these days.
thanks for your help is much appreciated
My knowledge of Intel boards is limited, but it will definatley work, i assune everything will stay at stock so that freq should be fine
Depends on the RAID configuration you are running. RAID 0, absolutely, but RAID 1, with mirroring, is much more secure since both HDs need to fail before you suffer data loss. I would say, having two Raptors in RAID 0 myself, they are very fast but relatively noisy, given you're not going to have a FPS blaring away. I'd have a look at the reviews of the Samsung Spinpoint, since these seem to be the quietest HDs around. Alteratively, look for some sound damping enclosures for the HDs
would you say then, it is too risky to put the hdd's in raid 0? I dont really know much about how realiable raptors are, so i would be guessing if i made a decision.
