Need help with website?
9 Jan 2011
Hereford
Hey guys, been making a webpage for my college assignment, and i'm having a few problems.
Firstly I can't get the page to scale on different resolutions(i.e. able to scroll down on smaller resolutions or to view more content.)
Secondly I want to bring up a frame or page when you click on the contact us button so it just brings up a little box with information instead of a new page?
Any other help would be great.
Website
Not sure about your scaling issue as I'm on my mobile and it looks ok - for the pop-up box, search for fancybox - its a cool javascript based window and pretty easy to implement with a jquery click event eve
For a start, you have near everything set to a fixed position.
Fixed Positioning
An element with fixed position is positioned relative to the browser window.
It will not move even if the window is scrolled:
Fixed positioned elements are removed from the normal flow. The document and other elements behave like the fixed positioned element does not exist.
To control the window that your link opens, you can use something like this:
Code:
<A HREF="javascript:void(0)"onclick="window.open('http://www.msn.com/','linkname','height=380, width=300,scrollbars=no')">Link Name</a>
It won't scale as the height/widths are fixed I think is what they are trying to say.
Nothing to do with widths or heights.
OP said that by 'scale', he means that the site won't scroll downwards. If you look at it and make your browser small so as to require scrolling, no scrollbars appear. This is because he's used fixed positioning on all his main divs which removes them from the pageflow and fixes them relative to the window.
