Need help.
Cooler cant be installed correctly?
If its the standard one then it will already have paste applied, meaning that thermal paste cannot be the issue.. Unless you removed it?
I doubt the fan not spinning would let it get to those temps on idle.
Ok, i removed the stock cooler and i had a nocta heatsink with 2 nocta fans on it which was in a bottom of one of the cases he gave me.
Was a rihgt pain to install it with no instructions and no idea if it fitted a 1366 socket, the only thing was i lost my MX-2 during tidying up and had to use some cheap crap :( and the backplate for the heatsink is haed against the backplate on the mobo covering the socket but nothing shorting will it be ok?.
Running prime 95 with 77, 75 74 70 max with both sides of the case on.
Changing the cooler also knocked 11 C of my gpu temps :D.
