Need help
11 May 2011
Farnborough
OK i'm going to buy This AMD Phenom II X4 820 to upgrade an older system.
I was planning to put it into my older system a Dell Optiplex GX620 tower case.
I heard this was not possible? Can you guys clear things up for me? I wasn't planning to buy a case or a PSU thats why i was going to put it into this system...
Thanks
--TidusJar
If you look in this table for the GX620, it will tell you that the MiniTower comes with a BTX size motherboard so you won't be able to upgrade to an ATX board I think.
Ah damn. What case and PSU would you recommend? I have 1 80gig SATA,1 400 Gig SATA, and a ATI Radeon HD 4xxx series card. Cant cost much :/
Ah damn... This isn't looking good for me then. I'm not 100% tech savvy so what would i need? I now need a case, PSU, and DVD Drive.
Your basketProduct Name Qty Price Line Total
Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core £156.00
(£130.00) £156.00
(£130.00)
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.99
(£54.16) £64.99
(£54.16)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) £28.99
(£24.16) £28.99
(£24.16)
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.98
(£13.32) £15.98
(£13.32)
Sub Total : £221.64
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 20.00% VAT : £46.58
Total : £279.47
thats the basics.
still need an operating system, do you have one to use? if not, relace the above harddrive with this bundle - http://www.overclockers.co.uk/showproduct.php?prodid=SW-000-OP
the motherboard in the bundle has an onboard gpu to get you going/do basics. For more gaming power a graphics card is need to get the settings turned up/play newer games.
That case will work.
The winpower PSU is nasty, its a known fact that any psu claiming 450w that costs around £10 new is poor.
Ok thanks a lot, So all i need now is a DVD Drive yes? or can i use the one in that case with the motherboard im planning to buy?
Thats ok then, I meant the old ribbon IDE style wide connectors like your optical drive.
So your here then,
(£130.00) £156.00
(£130.00)
BeQuiet Pure Power L7 530W Power Supply £42.98
(£35.82) £42.98
(£35.82)
(£13.32) £15.98
(£13.32)
Sub Total : £179.14
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 20.00% VAT : £37.93
Total : £227.57
Add your SATA harddrive or both (one for the boot drive, one for storage)
So the older ribbon cable i will need for...? Sorry i'm terrible at this. Also can i get any PSU to replace it?
You dont want any older ribbon cable, is your current dvd drive SATA or IDE?
the bequiet PSU above will be fine.
i dont know until you tell me.
As i said before the motherboard has no ide connectors so go from there.
you either need a new sata dvd drive or you dont.
