Volcs said:Turn NUM LOCK off!!!!
, you can half half if you want
.calnen said:Best idea so far tbh!
G-MAN2004 said:5 haven't g6t a n40 36c2!!!!!!
mleh said:you must have, as num lock is currently on.
Are you on a laptop? look at the top right of the keyboard, maybe under "Ins" or "Del"?
G-MAN2004 said:yes 5'0 6n a 3a*t6*. n6t 4nder "Ins" or "Del"![]()
and
when your P is doing * the rest of the time?Kol said:All keyboards have a num lock. It might be shared with Scr Lk. You will have one.
Instead of writing cryptic messages, which aren't helpful. Use the on screen keyboard.
I call shenanigans because one of your messages clearly had the letters O and I in it, when the rest of them were all 5s and 6s. Also, how can you doand
G-MAN2004 said:yes iM using character map but it takes ages
ED5T- So ive given up
ED5T2-![]()
Kol said:Haha, character map? Try start>programs>accesories>accesibility>on screen keyboard![]()
Angus-Higgins said:Then he can turn Number Lock off from On Screen Keyboard.
Angus Higgins
sormicoft said:they clone things
might try and cross you with dolly if your cheap enough![]()
honestly though how much do you need and when for?
neoboy said:There is a lack of registered sperm donors.
