that is obviously wrong
for example what if he had 6 dodgy teeth? According to that calculation you'd then have a probability greater than 1
see post #13
chance of at least one complication occurring = 1 - chance of none occurring
=1 - (.95 * .95 * .925)
approx 16.5%
if the probabilities are actually per tooth then for 4 teeth it is:
= 1 - (.95 * .95 * .925)^4
approx 51.4%
though this is all rather moot as the OP is probably making some dubious assumptions here
This has puzzled me and made me feel a bit stupid, so would you mind explaining something to me? (sincerely!)
Why are you multiplying? surely that's the probability of each of the complications occurring together.
Indeed, if you have 6 teeth and calculate it by addition you'll get an answer greater than 1, but that's ok because its no longer a probability - by multiplying by 4 (or by 6 in your case) you've just calculated the average fraction of all teeth that will be affected, unless I'm wrong?
If each probability is independent, and each tooth is considered a "trail" with a yes/no outcome (with yes being there's a problem -17.5%) then isn't this best represented by the binomial distribution?
In which case, I find:
P(0 teeth infected) = 46.3%
P(1 tooth infected) = 39.3%
P(2 teeth infected) = 12.5%
P(3 teeth infected) = 1.7%
P(4 teeth infected) = 0.09%
These add up to 100%, so seems correct in my head. Need someone to talk some sense into me though if i got it all wrong..
edit: so going back to the OP, the chance of developing any complication is (100-46.3)%, giving 53.7%.
