need recovery help
10 Oct 2008
Dundee
OK, I was partitioning a WD caviar green into 900GB and 600GB partitions, by accident I started with 2 750GB (simplifying GB for ease by the way) so I went back in to gparted on a live cd to delete them and start again (quicker than resizing them - they were empty). Without thinking I didn't change the selected drive, and managed to delete the 2 partitions from my primary 500GB drive and accept the changes. Now I have lost a lot of important data, I had my main windows install and my coursework on there - my backups managed to corrupt themselves.
Now, I haven't touched the drive any further, I know the binary information is preserved because the partition removal took no time at all. All it did was update some piece of memory which describes the drive's formatting - would I be right in thinking that? The most important partition is the one I had vista installed on, the first partition in the disk and formatted by the vista installer, before that there was a 20MB or so block of unallocated space and the last 200GB or so of the drive was another partition I am not bothered about losing.
How can I get my coursework back? Is the file table still intact?
I suspect there will be a tool I can download which can search for a signature of the windows installation? or is everything lost?
edit: http://www.cgsecurity.org/wiki/TestDisk - I think this could help me, any words or warning or wisdom before I continue?
Was going to suggest testdisk
Lucky you didn't got further!
Should always have backups of all your data anyway, so even if you do something silly, you can simply restore..
And most importantly, make sure your backups actually work, plenty of people do backups, but don't actually test them, and it's usually too late when they find out there is a problem.
