Pinter75 said:Thanks guys.
I do hope it works out, but for 2.5k it should be a load of fun.
Again thanks for all you help.
Photos to follow when I pick it up on thurs.
Pinter75 said:I have to start ordering stuff then. I just bought it for 2.5K!
Wheeeeeeeee!
DAvE18 said:got the lights aswell as part of a package deal. Plus I can take them with me when I get a 530d just got new job motorway muncher needed now lol
Pinter75 said:Pics to follow shortly. Hopefully gonna pick it up Thurs or Friday. I drove upto it tonight to have a look again, and it certainly looks sweet
I think it needs some nicer wheels, but what size is sensible? (considering bearings etc 17 - 18"?). I am liking the stock M5 wheels, or maybe the alpina style (R124/LA420 like the one you have.)
Another plus point is it has the de-chrome package, but I really do need to get rid of all that fake wood inside - carbon fibre or brushed aluminium me thinks I think it would look better with the grey leather.
Whats the deal with the dead pixels, I read somewhere that it is a duff connector? If so, Ill have a bash at that. On my e36 I built an interface board to connect a full auto close alarm to the central computer - so electrical stuff I am comfortable with.
The above applies to the e38 7 series. Its pretty much the same procedure for the e39.PIXEL restoration instructions-for MID speedo/tach (23493 views) (26538 thread views)
Instructions for removal and cleaning of MID (multi information display center)(the in dash unit containg the speedometer and tachometer) to restore pixels.
1.Remove 2 screws above tach/speedo with a T10 torx driver.
2.Pry out upper lip of housing with a flat blade screwdriver.
3.Disconnect 3 wire harnesses in the back of the housing and slide assembly toward passenger side of vehicle. (Make sure steering wheel is down and telescoped fully)
4.Place assembly face down on some type of soft towel and find and remove the wire harness going from the speedo/tach assembly to the module attached to the back. (Black plug at the top of assembly).
5.Push button on the bottom of assembly and slide the module sideways to free it from the front assembly.
6.Locate the five “X” type connectors holding the front onto the main housing. Twist these connectors slightly so they line up with the holes on the housing.
7.Press the four clips (2 on top/2 on bottom) and slide the assembly out through the back of the assembly holding the front clear covering (that covers the faces of the gauges).
8.Now lay the tach/speedo assembly face up on the towel and remove all of the torx screws on the face (about 8-10), this will NOT allow you to open the housing, but it will loosen it enough so you can get a spray nozzle into the circuit board under the cover.
9.Spray any and all connections you with the contact cleaner (non-residue/quick drying/plastic safe). Quickly dry the connections with compressed air (be sure to hold can upright to prevent liquid from being expelled)
10.Spray all holes and connectors and the connectors that plug back into the dash board. I also sprayed the actual connectors in the dash as well.
11.Reassemble the entire unit and make sure it is DRY before reinstalling in the vehicle.
This is what worked for me, it restored all of the pixels to 100% brightness.
Good Luck to all, BE CAREFUL!!!!
