Need some quick advice for backup hdd
4 Jul 2004
LDN
Hi all, think im gonna need some more storage to store some hi def content, as its eating at my current disk space. Im looking at as much space i can get, dont really want to spend more than 80 quid. As it will be used for storage (i wouldnt be comfortable installing an OS on such a big drive), i guess speed doesnt really matter. I want something quiet and reliable, and will prob want to get a 1TB drive. Also the less heat produced the better.
Quickly scanning, the western digital caviar green (16MB) look like a good bet. Anybody know how reliable they are?
Also within this price point is the samsung F1; i hear reliability might be an issue, but they seem mighty fast.
So im not sure really what to pick up; i guess a possibility is that this drive might eventually end up in a htpc also. Any ideas lads?
Thanks in advance. If there are any other suggestions please let me know!
Firstly since you're looking at storing a single copy of the data by the sound of things you're after a storage drive rather than a backup drive. Pedantic I know but there's a significant difference between storage and a backup.
There isn't a huge amount to choose between the WD and the Samsung, the WD will be a bit slower but for storage that's hardly a worry. Reliability wise it's difficult to tell, you'll only hear horror stories so you can't easily judge what the failure rate is. Unless you have a personal preference it might come down to tossing a coin, neither is a bad drive.
Yep definitely after a storage drive. i have read that the WD is only a 5400rpm drive, makes me think if i actually need a 7200rpm F1....hmmmm, decisions decisions!! anybody know what samsung or WD's RMA service is like?
