Need urgent fix, red cpu_light lit up.
It will overheat very quickly without any thermal paste. At best it will shut down at worst it will ruin the CPU.
I have the same cpu and mobo and it would not post because I did not have the cooler screwed down tight enough, put some thermal paste on and try tightening the cooler a bit
What?! - Why would you think it's OK to use it without, if so we wouldn't need it at all?! :confused:
I looked around on the internet and many places said it's not vital to have But very recommended, it'll will increase heat by 30-40% and honestly when uploading to YouTube t won't get that hot, like I said I earn needed money of this so it's important that I get it up, I guess il wait though
what psu? tested without the graphic card and using onboard graphics?
anyway to test with another psu
if its still doing it it can only be the cpu
