So, my job as a YouTube relies on my PC
Best start to a thread ever.
More seriously, have you made sure nothing is creating a short in the system?
what psu? tested without the graphic card and using onboard graphics?
anyway to test with another psu
if its still doing it it can only be the cpu
could be bios not supporting cpu or faulty cpu,one of those imo
You'd be best to do a fresh install. Probably boot manager and driver corruption.
uhh how would I. Do a fresh install, is that meaning lose everything on my hard drive?
Well, you would if you formatted it. But then, that's what backups are for. Which you doubtless have, for important files.
If you don't have backups, then try booting up Windows in safe mode and see if it runs up then. If not, then do a reinstall but don't format the hard drive - it should just replace Windows and your old programs then but leave all files/documents/etc on the hard drive intact. Then you can back up your files, do a proper format and reinstall, and re-think your disaster recovery plans!
So when I launch safe mode it does the same thing and goes back to the Asus loading screen and into the page where I get 2 options for launch startup repair or start normally. It's a bad loop.You tap the F8 key when booting up (press it before the usual Windows boot logo comes on screen). Should get a menu with Safe Mode as an option. From Safe Mode, you can get everything backed up.
