It's the only way into his back garden, I will need to check the deeds to see what type of passage it is.
If its his back passage then you know what to do!
Amazingly not one mention of letter box so far. gg gd!
Nope, He opens his gate, Passes through my garden, Opens my gate to get out with the bins which goes on to the street through a driveway, It's a semi detached house.
Easy stop letting him use your gate or passing through your garden.
What you can do about the gate will depend on whose land the gate is on, and whether there's any form of common right of access. If permitted, put up a fence, and maybe a lock on the gate.
As for noise, a puppy can still be loud, and if barking extensively, could potentially be a nuisance. What you can do will depend on what that letter ssid. If it was a noise abatement order, then your best bet by far is to abate the noise. Failing to do so is sn offence and could land you with a fine of up to £5000, though that scale of fine would be extreme.
Noise can be a "statutory nuisance". Your neighbour could initiate a compkaint, but it will be council environmental healthnofficers thst investigate abd determine the outcome. They will collect evidence, which could include a log from your neighbour detailing times, durations, etc. But the EHOs have to decide on the totality of their investigation, not just your neighbour's log, if any. That might involve sitting outside listening for frequency of noise incidents, how long it lasts, how loud it is, in order to assess whether it meets the criteria for statutory nuisance.
Part of the problem is that dogs that bark a lot tend to do so when left alone for protracted periods, which might be when you and your family are at work, school etc. If so, you'd be unaware of the severity because it doesn't happen when you're there. Also, puppies tend to be more insecure that adult dogs and particularly susceptible to barking.
I had that experience with a neighbour at my work apartment. The damn dog could bark and howl for two hours straight, non-stop, then take a break and be okay until something set him off again, which might be movement outside, or the phone ringing, or post being delivered, a visitor ringing his bell or even a plane going over. At which point, it'd bark or howl for another two hours. As I worked long but odd hours, I could be sleeping when the neighbour was out. Or trying to.
I don't think the neighbour understood why I was complaining until I invited him in for a chat when the rest of his family was out, and after about 15 minutes, his dog started up, howling. At which point, I showed him the log I had of times, durations, etc and he realised that 7 or 8 hours of barking and howling per day was not acceptable. Also, probably not good for the dog to be that distressed.
Nobody, or at least nobody sane, cares if a dog barks for a few minutes when someone's at the door or delivering mail, but hours and hours of it, day after day, really is an utter nuisance. And as for the howling .....
There are a variety of things that could be done. Perhaps, lock the dog out of rooms, if any, with adjoining walls. Perhaps, leave a radio on when out. The noise distracts some dogs. There are also devices you can get that are triggered by dogs barking. Some emit and ultrasonic noise that dogs don't like. It barks, it gets an earful. It barks again, it gets another earful. Apparently, that sort of reverse Pavlovian technique works and is usually only needed for a week or two to break the habit.
Other types of device go on your dog's collar and again are triggered by barking, but instead of ultrasonic noise emit a burst of a citric smell. When the dog breathes in to bark, it gets the citric smell which stops the barking. That's what my neighbour used and again, it was only needed for long enough to break the habit.
Just remember, if your dog barks when left alone, it might be driving your neighbour crazy, and you simply don't realise how bad it is. For the sake of neighbourly relations, I didn't want to cause a stir, but if necessary, I was quite prepared to use the noise nuisance route, and if that didn't work, private legal action through the courts. As it happened, it wasn't necessary once my neighbour realised how bad it was. A couple of weeks of citrus aversion therapy cured it of the habit.
If your dog is being a right pain when you're not there, dealing with the noise might go a long way towards encouraging your neighbour to cooperate over the gate issue, too.
I wish I could upvote this post like on reddit![]()
Very well said. There is a neighbor above me that has a small dog. They leave it all day when they go to work. On the odd day that I am off midweek, you can hear the dog barking for literally hours on end. The poor thing can bark and cry for 4-5 hours without a break.
That his problem then, not yours. If, like you say, you own the property then simply tell him to stop traipsing through your garden and to find another way of taking his bins out.
Not if he has access rights because it is a semi detached house.
In which case the OP is at fault and irresponsible here for leaving a dog unattended in there while others have access too.
