- 15 Apr 2016
Hi guys,
Really confused and spent hours trying to solve this one.
i am trying to stream from my 4k gaming rig to a laptop down stairs (Alienware m18x r2).
I have got high end power lines which are registering a transfer rate between the pair at over 900mbps.
The problem is whenever i try to use the powerlines my stream speed on steams diagnostic goes from nearly 1,000mbps to 2mbps, making it unplayable and rubbish.
What have i tested?
-All cables.
- direct connection to router - no issues and runs at 2,500 mbps.
The reason i am puzzled is because the power lines are communicating at nearly 1GBPS ? I am not very good with routers and the whole setup etc, but could my router be automatically be adjusting settings when it detects a powerline ? i have an Asus N66U router, so not a cheap freebie.
The computer upstairs is connected via a powerline directly to the router downstairs via a second powerline,, the laptop has been tested via WiFi and also ethernet into router
Any help would be appreciated.
What have i tested?
-All cables.
