Network Switch Speed drops after time
16 Apr 2022
Glasgow
Hi,
Tried two different switches, issue is on powering up switch I'm getting in the region of 400-600 mps. If I try it the next day I'm getting 10-20 mps, reboot it and its back to 400-600 mps. Using a virgin media router with cat 6 cable. Anyone know what the issue is??
2 Sep 2016
You been in to the router to see what connection speed it is reporting to the pc, you can check the other end on the pc. you using a network switch or a old repurposed router?
Don
21 Oct 2002
Parts Unknown
Make sure there's only one cable between each switch and router.
IE, don't connect multiple ports between the devices. This will create a network storm.
Also, try replacing network cables. Could be a damaged one.
