So it's not memory speed bottlenecking it, GPU limiting it?It's the same with gaming performance, there is no improvement with faster memory
Thisnis even at 720p cpu bottlenecks
It's the higher latency from the timings, we need kits with better timings, just adding higher speeds isn't doing anything above existing 6200 CL30 performance
Hopefully I will get 6400 out of the 6000mhz ram from corsair then doubtful ... but will try it. Waiting on MSI to release the update for my board.In todays GN video they said after the update more PCs will be able to run 6400 in 1:1 which should improve gaming performance
What are the current big bottlenecks in gaming performance?In todays GN video they said after the update more PCs will be able to run 6400 in 1:1 which should improve gaming performance
Apparently 6200mhz 1:1 is the new sweet spot, previously 6000mhz anything over requires you to run the IMC at 1:2 unless you have a golden chip.From what I've read so far gaming performance is actually worse when hitting these speeds on the ram? I don't think the update is out yet for me on the MSI tomahawk x670e anyway.
suspect it will still be the highest speed you could run 1:1 as it was in AM4.Im going to be building a new system soon, i know im going with a 4090 and a 7800x3d but not yet decided on mobo and RAM. I'll be interested to know what the best RAM/mobo combo will be with this new agesa.
ATM im thinking to go with the f5-6400j3239g32gx2-tz5rk gskill trident and the x670 aorus elite.suspect it will still be the highest speed you could run 1:1 as it was in AM4.
So 6400ish on a good motherboard
waiting on the b variant bios this one is terrible not sure why i have lost clock speed though since when i built it it was going as high as 5.6 on some cores![]()
no was just venting my frustration at version A with the expo 2 profileThis is the B version. Wrong thread?
