New Aston Martin Valour - 705bhp V12 + manual gearbox
NVP
NVP
6 Sep 2007
Aston Martin has unveiled a new supercar heavily inspired by the jaw-dropping, one-off Victor – and equipped with a thunderous 705bhp V12 and a six-speed manual gearbox.
With design cues taken from the original V8 Vantage and Aston Martin’s snarling 1970s RHAM/1 prototype racer – known as ‘The Muncher’ – the new Valour is the firm’s 110th birthday present to itself and a celebration of its hallowed 12-cylinder engine.
Just 110 examples of the Valour will be sold at a price understood to range from £1 million to £1.5 million. Each buyer is invited to customise their car through Aston Martin’s Q bespoke service, offering one-off liveries, an exposed carbonfibre body finish and a raft of interior personalisation options.
Whereas the Victor was based on a surplus One-77 prototype chassis, the Valour is built around a bespoke body structure – thought to be derived from the V12 Vantage.
The 5.2-litre V12, based on that of the DBS, sends 705bhp and 555lb ft to the rear wheels through a specially designed six-speed manual gearbox and a mechanical limited-slip differential. Mating the V12 to a manual gearbox (the DBS, DB11 and Vantage all use ZF-supplied automatic gearboxes) was “a big part of honouring that driver-pleasing character”, said Aston Martin engineering boss Simon Newton.
The dynamic brief for the Valour, said Newton, was to provide a “state-of-the-art driver’s car” with “the true heart and soul of a timeless analogue classic” – a point emphasised by the manual gearbox’s visible shift linkage. Modifications include the fitment of front and rear shear panels, a rear suspension tower strut brace and fuel tank bracing, boosting rigidity.
The car also receives adjustable dampers and a new power steering set-up intended to provide more granular feedback through the wheel. Stopping power is provided by standard-fit carbonceramic discs measuring 410mm by 38mm with six-pot calipers up front and 360mm by 32mm discs with four-pot calipers at the rear.
They are tucked behind staggeredwidth 21in ‘honeycomb’ alloys – familiar from the Victor and DBS 770 – shod in Michelin Pilot Sport S 5 tyres. The Valour is not solely about brute force. The brake set-up provides a 23kg reduction compared with steel equivalents, the exhaust system is made to a sub-millimetre thickness to save a further 7kg and the bodywork is made entirely from carbonfibre.
The design is a slightly softer take on the brutal Victor but retains its bulging bonnet and abrupt Kamm-tail rear end. The front splitter and arch vents work with the rear windscreen louvres to generate a vortex and flow air neatly over that tail, said Aston Martin.
The model serves as “further proof of Aston Martin’s position as the driver’s champion”, said company chairman Lawrence Stroll. Deliveries of the Valour will start between September and December this year.
Looks like the classic Vantage was re-designed by the defunct Fast Car crew with Halfords parts.
A sea of nope from me.
DB12 is much better looking.
But then when you buy something like this it’s all about the rarity factor isn’t it.
One heck of a gear knob on it.
Looks like it can't decide if it is a Jaguar or a Mustang... (EDIT: To be fair if they swept the lip at the back instead and had a mini-wing integrated into the design, slightly tweaked the front bonnet lip and changed the alloys it would look pretty good).
A road conversion Vulcan would be an immense looking car though.
Nice car but if I could order one I would ask for the tractor wheels to be taken off and fit it with a auto box.
Just the car for popping down to Lidl.
