I hope to take the plunge and get a new PC.
My previous PC's have all come from O/C, and have cowered from building the machine myself.
This time after spending more time researching I am going to give it a go and do it myself.
With this in mind to offset my lack of build experience if the case or mobo I have listed do not lend themselves to novice builders I am open to ideas.
The machine will be for gaming, with my benchmark being Flight Simulator (I know this is taxing). Which I really want to get into. I plan to play at 1440p.
I am holding out for an RTX 3070 FE - and plan to use Telegram to hunt one down, my patience is not the best so I might have to resort to buying a pricey branded card if I have no luck.
I can use my old GTX1660 super for the mean time.
My budget excluding the GPU and monitor is around £1000, but I will go a little higher if I have too.
As I am gaming most of the time, I would be happy to strip back a little in any areas if there is not too much of a performance sacrifice. I do want to go down the Intel CPU route though.
Regarding storage I have 2 x 1TB Samsung 860 EVO SSD's, which seem fine. Unless of course its felt I would really benefit from some NVME's.
I would appreciate any help on further fans and fittings I might need, I will use current peripherals.
My basket at Overclockers UK:
Lastly I am also going to have to stretch to a monitor (1440p), I am less clear here. I wpuld like over 100hz response if possible. I would be happy with a 27", and the following have been suggested:
Gigabyte G27Q or Gigabyte G27QC. Any help here would be great, and preferably under £300.
Thanks in anticipation.
- 1 x Intel Core i5-12600K 3.70GHz (Alder Lake) Socket LGA1700 Processor - OEM= £278.99
- 1 x MSI MAG Z690 Tomahawk WIFI DDR4 - Intel Z690 DDR4 ATX Motherboard= £259.99
- 1 x Lian-Li PC-O11 Dynamic Midi-Tower - Black Window= £135.95
- 1 x Patriot Viper Steel 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit (PVS432G360C8K)= £99.95
- 1 x Arctic Liquid Freezer II High Performance CPU Water Cooler - 360mm= £94.99
- 1 x Corsair RM Series RM850 850W '80 Plus Gold' Modular Power Supply (CP-9020196-UK)= £84.95
Total: £968.02 (includes shipping: £13.20)
