- 1 Dec 2015
Orb little bit of a problem? his computer seems fine playing most games, but when hes trying to play ARK its overheating, shutting itself off while like the power light and everything stays on but the display just goes black? think its just the graphics card getting too hot, also noticed the case has an extractor fan on the back but no fans inside to pull air into the case, should I order some to sit in this spot to get some cold air into the case?
and is there a reason its overheating just on this game particular?
vega chips do run hot , able to get him to run an overlay program to see GPU temps when gaming ?
handy guide here
https://forums.overclockers.co.uk/t...king-undervolting-information-guide.18793012/
funn enough, undervolting vega chips gets the most of the chips, will allow it to run cooler and faster .
good airflow will always help , difference between fans and no fans can knock down component temps by 10c+ Front fan will supply GPU with fresh cool air as well as some positive pressure to stop dust build up inside the case
