Ok, I have been going back and forth between buying a new PC or building one and I have decided its time to become a real man and build one.
I currently have a a real bad AMD2 motherboard with an Athlon which is running out of time.
I do however have -
GTX 460.
OCZ 650w PSU
Along with DVD/CD drives and SATA Hardrive which I plan to re-use in my new build. Although once I have the main components sorted I may get a bigger better HD.
What I am looking for help with is the rest. I have a budget of about 500ish quid.
I want to be able to run the likes of Guild Wars 2, Skyrim etc decently.
I was looking at the i5 3750k as the base to work around.
Dont need any Peripherals , OS or Monitor.
Looking mainly for CPU, RAM, Mobo and a decent case.
I think that is everything.
Cheers.
I do however have -
GTX 460.
OCZ 650w PSU
Cheers.
