New build issue....plz help!!
yups, bit of a bummer that youre sending something back before getting started :(
Btw, I only plugged 1 4 pin connector into the mobo near the CPU, because thats all that my power supply has...i left the plastic cover over the other 4 pins...and it powers up fine...does it HAVE to have the 8pins? or can it run fine off 4??
I've contacted Overclockers to arrange RMA.....hopefully it won't take too long although they've said there going to email me and I've just realised they've got my email address wrong :(
Guess I'll have to wait until Monday now unless anyone on here can advise what the process is for RMAing a MB?
Thanks to everyone for there help and suggestions in trying to get my issue resolved :D
Cheers
It should be able to run fine off of 4, the extra 4 are there for stability I guess if you have your CPU at lolGhz.
Found this in the instructions for the MOBO:
Use of a power supply providing a 2x4 12V power connector is recommended by the
CPU manufacturer when using an Intel Extreme Edition CPU (130W).
