NEW BUILD NEED HELP
10 Jan 2011
Hello guys,
I've just taken delivery of all the bits I brought from here, it's now all built up but whe i turn the pc on it's starts for a secons then turns off few seconds later its on again then off, just repeats this what could be the problem??
Have you connected the extra 4/8pin into the motherboard?
is the cpu heatsink fan connected tothe FAN_HEADER on the motherboard?
some specs would be useful so i dont have to guess as much:D
Gainward GeForce GTX 470 "Golden Golden Sample GOOD Edition" 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor with FREE Lost Planet 2 PC Game - Retail
MSI P67A-GD65 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge)
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G)
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599)
Antec TruePower New Modular 650W Power Supply
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
Arctic Cooling MX-3 Thermal Compound
At last check you went with this? Check what Stulid said as a start! then with 1 stick of RAM in the correct slot
Simplest thing to do is check all connection. Disconnect and reconnect everything to make sure.
Does the PC make any beeping noises? or does it literally get power to it and the automatically switch off?
no it does not beeb just turns off i;ll try with 1 stick of ram
still nothing even with 1 stick of ram, the power supply does not have a 4/8pin to plug in it only has the 24pin
It should have both, 1x4pin and a 1x8pin plug.
When the PC starts, does it litterally last for a short split second?
If so then take everything out of the case, and test the system then. I've seen this problem a few times, and some of the causes is the case shortening the motherboard.
SATA connectors, and the SATA power connectors can be a crap fit, double check it.
Is the HDD seen in the bIOS?
The SDD is seen in bios, I think I have got it working as windows is now installing, one more question if i may??
I'm going to sli the gtx470s card the motherboard come with a ski bridge but no instructions on where to plus it in on the two cards?? any ideas
nope, just use the headers closest to where it screws into the case.
The other header is for when you add a third or fourth card.
