NEW BUILD NEED HELP
for your first start up and installation of windows.
DVD drive first.
SSD second.
then once its all installed and running, go back into the bios and make the SSD first and disable all other boot devices, this will speed up the boot up time.
DVD drive first.
SSD second.
and once windows is complete change it to sdd dvd hdd??
stupid questions but how do you get in the bios i thought you press F8 but that just takes me to an option to have save mode?
And, the AHCI mode should have been enabled before you did the install.
TRIM support for the SSD may not be working otherwise I think.
its all up and running ive even clocked it 4.2 i dont fgeel brave enough to go higher but i cant get the ram to go above 1333 i wabt the full 1600 from them, it's all sitting around 35c not to shabby
