Hi all,
Ok, this is on a build for my mate I did.
System is:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz - o/c to 4.00GHz
Gigabyte EX58-UD5 Intel X58 Motherboard
Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3
Corsair 850Watts
G.Skill 128gig falcon SSD
Vista 64
ATi 4870 x2
Try and be as brief as possible.
Chucked it all together fine, booted up, installed windows and all good.
Loaded all the chipset drivers etc... on from the mobo CD and then rebooted and it said that there was no operating system. Went to the reinstall page and it said that the drive had 119gig free of 119gig total. So in effect nothing is on the disc?!?!? odd.
BIOS running IDE, not ACHI.
Anyway, I installed things one at a time, reboot inbetween and everything seemed good.
The other day the system just hangs, tried to recover off the disc, but it was not having any of it.
So I reinstall from fresh. This time though, under ACHI as I have read things about this. All worked fine. Then installed ARMA 2, rebooted and DONG, no operating system. 119gig of 119gig available. WEIRD I hear you say?!?!
So, tried another SATA port, same thing. Another lead, same thing.
BIOS is F7, which is the latest update.
Running out of ideas, so I put it in my computer as a second boot disc.
Installed windows, drivers, games, everything. Installing two things at once trying to mess it up and its fine in mine.
So the main question is, whats wrong with his!?!?!? Im stuck now, its beyond me. I cant think of anything more to try, other than another SATA port and cable.
HELP!
System is:
Corsair 850Watts
Vista 64
ATi 4870 x2
HELP!
