Hi Community!
I've just finished my custom loop, which consist of a EK XRES-100 D5 revo pwm pump/res combo, EK Strix 1080 Ti gpu block, EK Velocity CPU block, 1x 360 Bykski 28mm radiator, 1x EK PE240 radiator, Aquacomputer HighFlow LT flow meter and 5x Noctua NF-F12 Chromax pwm fans. All this is controlled by an Aquacomputer OCTO. I'm using XSPC 11/16 soft tubing and XSPC 11/16 compression fittings.
The D5 running at full speed and my flow rate is 75.10 L/H. I think it should be higher...
What you guys think should I be worried about my pump, or is it ok?
Thank you very much for the help.
