I've done it again.
Since the 1.8 blew up (my fault, it died on a rolling road power run) I needed to get her back on the road. So, I was lucky enough to source a Spider Cup racing engine.
Basicly it's the same engine as the 1.8, but stroked (iirc) a little to bring it to a 2.0l. The sump's slightly bigger, and the head's a little different and it's got some slightly wilder cams in it. The engine's been blueprinted, balanced, the valves are triple angle jobbies, compression's been raised by skimming the head and decking the bottom end... Needless to say, it's a pretty good spec. It's capable of revving to 8k on the race management, but I'm running a basic remap of the factory settings which limits the fun to 6.8k - but to be honest there's no need to take it that far.
Whilst the engine was out it had a few new things thrown in as well - new clutch, gearbox, PAS pump (which is buggered now, joy), water pump, all the belts, steering bushes, filters etc, so she drives like a new car. It's still economical too - 35-40mpg on a run which i thought was more than acceptable.
Only niggles so far are the PAS pump which is on the way out and the exhaust which is knocking since things have been moved about. I'm going to get a midbox put in to help give a bit more backpressure soon and whilst they're at it get them to fix it in place a bit better!
