.Stevie and Mark looked after my EP3, they're damn good. Glad you've got a potential solution. You on with Honda for a different sensor?
Do you need a DC5 one or an EP3 one? Assume the Speedo will be be reading incorrectly too.
Could be expensive the if they have to pull the gearbox to fit it
Wouldn't have thought a speed sensor would be silly money? Not that complex a part...basically just a hall sensor?
Stevie at eightspeed is a good guy though, really helpful. Hopefully get it sorted quickly. If its a main dealer only part then let me know, have a contact who might be able to help on the price.
You're reading in KPH as it's a JDM box, so make sure you order a converter if you need to get a DC5 VSS
apparently i need to get the cog or the VSS
8speed never mentioned about the converter. i guess that would be required if i used the dc5 sensor and not my current ep3 sensor with a dc5 cog?
