New GPU - low fps with low gpu/cpu usage!
There are two PCIE connectors and one CPU connector all labelled - I've connected them the way they are labelled - is it worth trying to swap them around?
Not if the cables are hard wired into the psu.
Try a program called rmclock by googling rmclock, and use it in windows to set the ratio from x8 to x16 to see if the MHz changes to 1600mhz.
If they are the correct way around, then don't change it. It was only if they weren't labelled and you had mixed them up i figured it could be a thing!
I cant get rmclock to work properly - it doesn't recognise my cpu. It knows its Intel, but 'unkown model' :(
Some more info here:
In the bios with gpu in:
cpu frequency 800mhz (roughly)
BCLK100mhz
temp 23
voltage 0.828 V
Without the gpu
cpu frequency 3701mhz (roughly)
BCLK100mhz
temp 31
voltage 1.128 V
Does this tell us something about the power being supplied?
If it's doing this inbetween power ons, with out going into Windows at all between swapping the card in and out, you can probably not worry too much about any windows settings at the moment.
I see you've updated the BIOS and done a reset to defaults. Have you tried clearing the CMOS? Should be in the mobo manual somewhere, normally along the lines of removing the mobo battery or setting a jumper pin etc.
Might be worth clearing the CMOS and then re-flashing the latest BIOS again.
Looking at the spec posted there doesn't seem to be a lot of extra h/w but is there anything you can unplug or disable in BIOS?
As from your above post it looks like you can see the issue in BIOS without going into the o/s, you could unplug the HD, unplug any uneeded USB devices (don't really need a mouse for BIOS for example), disable onboard LAN, sound etc.
Probs not going to make a massive difference to power draw (certainly not compared to a CPU or GPU) but if you are at the limit it might be enough to get you under. But tbh PSU should be fine.
There is no Hyper View - did I need to turn that off in windows before I turned off VTd in bios?
I disabled VT-D and if you search for Hyper V in Cortana it should bring up a window and you will see it there - make sure you untick it.
Oh well - looks like it's dead! Restarted, got 5 short beeps, which I think means the cpu is broken?!! Tried rebooting twice, same thing! :(
Unplug the system and remove the CMOS battery for a few minutes,put it back in and then see if the system reboots.
I wonder if the PSU has an issue.
Thanks for all your help - but I think I've killed the bloody thing!! See previous post.
The PSU is quite new??
A CPU rarely dies - either the motherboard has gone,or the PSU has a fault.
It makes me wonder whether the PSU has a fault - the VS series are not that brilliant as PSUs go IMHO,and it probably didn't help you used a cheapo no-brand one before you bought the new card and PSU.
Edit!!
As I mentioned before:
" Unplug the system and remove the CMOS battery for a few minutes,put it back in and then see if the system reboots."
As you've been in and out of the case a few times swapping the card in and out etc, double check you haven't knocked anything loose. I'd probably go all out and physically remove and replug things, rather than just give them a wiggle/push them back in.
And try resetting the CMOS.
I'd probably pull the power out the back of the CPU, disconnect everything, remove the mobo battery, go and have smoke, a NCoT, chill for a bit then put it all back together bit by bit.
Thanks - going to sleep on it, and try again fresh tomorrow. Thanks for all the help!
Edit!!
To salvage this - any recommendations for a better choice of mobo and psu, presuming that the cpu is OK?
These both seem to be solid PSUs:
https://www.overclockers.co.uk/supe...0-plus-gold-power-supply-black-ca-002-sf.html
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020101-uk-ca-219-cs.html
https://www.overclockers.co.uk/be-quiet-pure-power-9-500w-80-plus-silver-power-supply-ca-11g-bq.html
AFAIK,these PSUs seem generally fine,and for a GTX1060 or RX480 a decent 450W to 500W PSU should be OK(I am running a GTX1080 off a decent 450W PSU for example).
Edit!!
The CX-M series is the newest(but less efficient) of the designs(uses a more modern design IIRC).
