Caporegime
- 9 Nov 2009
- Planet Earth
It might be worth reading this:
http://www.overclockers.com/forums/showthread.php/734527-4770K-stuck-at-800Mhz-!-!
https://rog.asus.com/forum/showthread.php?82089-Skylake-i5-6600-stuck-at-800mhz/page2
The problem isn't the board.
It's a Windows setting.
Someone recently had a problem like that, and it was a specific setting in the Power Options. Make sure that High Performance is selected. Then click Change Plan Settings. Then click Change Advanced Power Settings. In the Processor Power Management setting, make sure both the Minimum Processor State and Maximum Processor State are at 100%
He said it was working fine until after a Windows update, and when he checked the Maximum setting as part of his troubleshooting, it was at 5%. Switching it back to 100% fixed the problem.
Hopefully this caught you before you switched boards, as you could have this very same problem on any board.
