New PC build help
LOL thanks tbh wasn't to stressful, I followed a you tube vid to fit the cpu cooler and the rest was simple :) Ned to have a tidy up in the case it looks a mess!!!
using SSD for win 8 (loads windows in prob 10-15 secs)
Got a older sata 250gb going for win 7 x64 on that so duel boot :)
Seems pretty stable and I really like the one charge motherboard app
http://uk.gigabyte.com/MicroSite/185/on-off-charge.htm
Is there a thread on this forum to get the most out of the motherboard hints and tips etc?
Got a chance of getting a couple of these cheap!! Gainward Nvidia GeForce GT 220 graphics cards. Any thoughts and can I run SLI with my setup?
No budget as such, but it's more a case of what I need I rarely play games, seen on here that quite a few have bought second hand GFX @£60 that seem to be bang for the buck, using a older monitor setup atm but again intend to upgrade to a newer one in the coming months
If you don`t` play games, then there is not much need for a Gpu, other than better BD playback. But if you feel you need one, then 2nd hand or keep an eye on the clearance section for a bargain. A GTX460, HD6850 or HD7750/70 may be ideal.
What games do you actually play?
it would be more for my son, myself I like civilization type games would be good to get back into them after all this time :) My Son is mad on minecraft
Just found a old Nvidia 7800GT lying about seems to be a good improvement but still only 4.1 windows experience (win 8) least I managed to get a couple of old monitors hooked up :)
Just got hold of a Gigabyte HD7750 second hand I saw the card working before i bought! When I put it in my system I get no signal to monitor, tried 3 monitors and a HDMI :( any ideas? Sorted had to change the bios to legacy :)
hakank68 Thanks for the post, however I have now bought my PC (see earlier post) this was just a follow on as I now have a GFX card for it
Flash the motherboard BIOS using Qflash to the latest one.
The D3H needs this done, been many reports before with it not working with certain cards (mainly the 7850)
Ok have a small prob with the Gigabyte HD7750 VGA to Monitor is fine I bought a DVI-D to VGA adapter for my second monitor, plugged in not working, windows doesn't detect the second monitor? Any ideas?
