New Pre-Built PC - Advice Received - Double Check before purchase.
29 Sep 2011
melee island
stuck with @Tetras suggestion
good call, his suggestion is 100% sound, in fact he is probably the most helpful person on this forum, just in case you were wondering, that cpu comes with a air cooler included, it's not a hard cpu to keep cool, it's maybe a little loud, but will totally see you through while you keep an eyen on CPU temps when in general use, if it turns out that you are not happy with the temps, or the noise then you can come back and look in the cooling sub section to find out the current best value air cooler, right now there seems to be two that stand out from the rest
enjoy the build!
