** NEW PRE WATERCOOLED CASE RANGE FROM OCUK TECH LABS **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
It gives me great pleasure to announce a new series of pre watercooled cases from tech labs.
We take care of everything ensuring that you only have to install the CPU block.
We have a choice of Mayhems coolants available and some products give you a case colour option.
These use standardised Water Cooling hardware that offers immense performance based on proven testing and results.
To make things even more interesting, the Prodigy and Phenom cases come with altered versions of our popular Tech Labs Fathom coolers which are capable of keeping an AMD APU at 5GHz on the 240mm radiator astounding results.
Check out the range here
Corsair 750D
NZXT Phantom 410
Cooler Master HAF X
BitFenix Ronin
Cooler Master Cosmos SE
I notice you have the 900d with bay res and im sure as I have a 900d and a bay res that does not fit, also im sure im someones build log they say the same thinig how do you guys get it to fit ?
What a great idea to get started with water cooling! Tempted by that 750D for my next build. Would it be possible to have compression rather than barbed fittings though?
Yup. Fitting a water block is even easier than fitting most heatsinks too.
Yeah I agree. Well 2011 (I think) is the easiest because it has a backplate attached so heatsinks aren't hard but waterblocks are very easy to fit.
@Kelt I can't see why not, just make the order and ring support. That works for most things.
All of these come with xspc compression fittings which are the most secure we have tested.
they do fit, not sure what problem the user in question is having?
we fit two of the 750 version in the front of this build with no issues at all?
the design is different but not enough so that it wouldn't fit.
I can only assume that if there is something stopping it fitting perfectly then we can make the necessary adjustments to the chassis to ensure it fits whilst keeping your warranty in place.
Pictures will be updated as sales take place
we are in planning stages of a video to go with the range for OcUK:TV also :)
Need pics :D
Good idea for people who aren't too sure on what to get but want to make the jump to watercooling.
I'm interested in the 750D On the details page it says :
- G1/4" to 1/2" Barb (Black Chrome) x6
- Plastic Hose Clip x6
I just wanna double check it comes with compression fittings. Also is it possible to change the colour of the tubing if possible?
Cheers!
Got my eye on the phenom(not decided on mitx or matx), do you only do the 140mm rad for the matx and no 240mm option like with the mitx model?
Well its either the phenom or the evga hadron hydra if/when its released, looking building a PC to put under the TV/next to the TV cabinet (depending on if it can fit in the TV cabinet) may also use it for iseries events if I start going again (last time I went byoc was while it was in Coventry. Not been to it since it moved to Telford).
yes.
its intentionally like that.
you could probably fit a 240 in the roof of the matx phenom/prodigy but it would mean that it would be incompatible with any setups that include graphics cards larger than two pci slots
we didnt want to end up having to write a comprehensive compatibility list as it ultimately would never be 100% accurate.
this way the rad is mounted on the rear of the case and out of the way of the cpi devices and hard drives.
Cheers!
ah i see i have made a mistake.
the compression fittings are used on the cases with 'custom' in the title.
the other ones are comprised out of our XSPC kit listings as they represent better value to the customer.
as they come in a box it is not possible to change it.
you could however, ask sales to create you an order for technical to build using the individual components
post in the CS section for mine & 5UBs attention and we will sort it out for you.
