ah i see i have made a mistake.
the compression fittings are used on the cases with 'custom' in the title.
the other ones are comprised out of our XSPC kit listings as they represent better value to the customer.
as they come in a box it is not possible to change it.
you could however, ask sales to create you an order for technical to build using the individual components
post in the CS section for mine & 5UBs attention and we will sort it out for you.
I placed an order for the watercooled phenom with 240mm radiator a couple of days ago. I was wondering:
1. if you would be able to add a 140mm Radiator to the loop to cool down a gtx 770
2. if the Eisberg Prestige Jetstream CPU Liquid Cooler's pump that comes with the water-cooled phenom would be powerful enough for the loop.
I don't really need the hdd trays so 140mm radiator would fit in the front.
cheers.
Thanks for your reply.
I see. shame really as it is a small case but can accommodate dual rad. would you be able to provide this as an extra option with my order? or should I order the pieces separately?
many thanks.
We can't sadly as you would need to include the GPU block into the loop making it impossible to install onto the card after.
If you have a plan in your head of a complex WC solution then it is best to do it yourself.
If you are dead set on that plan, maybe consider a post in the water cooling section asking for some advice. That way people will present you with some more options you may not have considered
