Wheels arrived today
Ordered the rest of the bits to get it finished too. Just waiting on them being made, MK are quite busy atm.
lol seems like that long ago, 2005 I think it wasGet on with it Pez, didn't you start in 2003?
roj tis me!Perywinkle - i take i you are Pezza from locostbuilders?i thought i recognised these pics elsewhere hehe. you have the same location too
Planning on supercharging it eventuallyYou gonna blow it?
I might add some red rim tape for a dash of colourNoo, black on black with extra black. Stealth bomber!![]()
Done **** all to it since the last update, had sod all work and even less money lolhows it comming ?
What a strange choice of manifold...Why not a simple log one? More efficient and a lot less volume. Probably a hell of a lot cheaper too...
*n
Gonna be road legal and track toyabsoluyelt mental, it going to be road legal? or a pure track tool?
Hurry up Pez, I want a demo next week.
*n
looks like it could be equal length, in which case the turbo would spool a lot better than a standard cast piece.
Cos its revs like a bastid and he probably wants as low TIP's as possible.
Revs have nothing to do with it. It is all about flow.
Yes, it may rev to 13k but it's only 1300cc so it is no different to a 2.6 with a 6,500rpm limit...
*n
I was always under the impression that primary lengths were inconsequential on a turbo'd engine and that manifold volume was king...
*n
*n
volume is indeed important, but so is velocity. the quicker the exhaust gas is filtered to the turbo housing and with as little turbulence as possible means the turbo will spool much quicker - works best with a twin scroll turbo mind.
Thats more to do with the pulse effects from each cylinder rather than velocitys.
Log manifolds are crap as a lot of the gases simply go up the adjacent cylinder exhaust port rather than towards the turbo. Twin scroll have seperate entry points into the turbine housing. This separates the two (on a I4 engine) matching pairs of cylinders from one another. This means that the pulse of exhaust gas from that cylinder can either go down the matching cylinder exhaust port or the turbo. 1 + 4 and 2 + 3 are the matching pairs.
With a log you can see that rather than having two options, the pulse has 4 options of where it's energy can go/is absorbed by.
