New PSU advice
20 Jun 2011
Looking to move my existing Coolermaster 650w PSU from my main computer into an older computer so that the little ones can use the other computer...
Looking at the PSU below
http://www.overclockers.co.uk/showproduct.php?prodid=CA-165-CM&groupid=701&catid=123&subcat=
This should be enough to run whats in my sig shouldn't it ??? I also plan to upgrade the GFX to a GTX670 in a month or two. 'If' i decided to sli in the future would 750w be enough or should i aim for something higher ??
Good PSU for the price but a few people have had issues with the SATA connections on some of the cables.
In terms of power 700w will be ample for your system.
