As Quartz mentioned, the Intel CPUs have been replaced by a new generation and since they're potentially problematic there's not much reason to buy one apart from a great deal.Ah. I like to consider myself brand agnostic - but I have to admit I've always had Intel, because they've always been the suggested best at the time I was putting together a system. And, probably largely because of that, I understand their naming patterns better!
The 15th gen is not called 15th gen, it is "Core Ultra". The Core Ultra CPUs are not bad CPUs, for productivity or mixed usage they're actually pretty good and improvements over 14th gen. Unfortunately their gaming performance is not great (relatively, they're not terrible) and their performance (even after all the fixes/updates from Intel) remains somewhat inconsistent.
We're learning what memory works best for them and they do appear to respond to that, but the AMD X3D CPUs are still what I'd pick for a gaming focused build.
The 2nd gen boards are: X870/X870E and B850/B840. 1st gen boards (670/650/620) will still work for a 9000 series CPU (were meant for 7000), but they might need a BIOS update for full support.I guess the same question holds true for the motherboards though - just the AMD compatible equivalents. What would they be? Something like the MSI X-870P and the ASUS X-870F?
If you want PCI-E 5.0 graphics: you will need B650E, B850 or X870/X870E.
PCI-E 5.0 M.2 can be available on any board, but it depends.
X870/X870E has mandatory USB4, but B850 does not.
If you plan on a lot of storage (filling the m.2 slots) X870/X870E can be more problematic than B650E/B850 because the USB4 steals (on most boards anyhow) 4 CPU lanes.
There's a detailed spreadsheet of the features linked to here, which has been updated for the latest boards:
The 9070 XT/9070 are competitive on price (if you can get one and at the price they're supposed To be) and I'd normally suggest you check them out and see if they can be good enough,.. but I don't know how they do with VR.Same is true of nVidia for the GPU for that matter.
You may want to read this thread:
AMD 9070XT VR good idea?
Looking to get a new GPU for mostly VR and I was going to go with 5070TI, but it's crazy £900+ prices don't seem like a good idea. Only thing not being 100% on AMD is I read it's not as supported in VR as NVIDIA over wireless using virtual desktop. Using my RTX 2070 in VR been very good with...
