New to pcs looking for help :(
Recon this is worth a try tonight ?
I did try switching between the graphics card and the integrated card on the motherboard , but didn't work :/
With the hdmi in "integrated " if I turn computer off them turn it On it just goes straight to windows start up
With it set on the graphics card it shows the green screen
Then if I don't press anything it will go onto the start up of windows
Think it might have Sumet to do with my tv?
With the tv set to "pc" anologe lead "which is the actually graphics card(9800)
Turn it on it does this straight away
Then this
Now if I press del it does this
that's wierd so your saying now that you can't get into the bios somethings up when you turn it on with the integrated graphics does it take a while before the screen shows anything? do you have a pc monitor you could use
It does take a while to show up on the hdmi but of I turn the tv to pc then u can still see the green asus on there but then it goes off then if I switch back to hdmi it shows the windows load up , I'll borrow the monitor from the pc room upstairs sure my brother won't mind haha I think it is to do with the tv tho , it's only 3months old the tv I'll give it a try when I get home tonight thanks again
Shall I overclock through the CPU reference clock mhz or just use the auto overclock which is best ?
I'd not recommend pushing a manual overclock without that replacement PSU for now, it would be pointless until you have the other components anyway.
In the mean time have a read up on the overclocking guides floating around here for a good understanding on what you can achieve. Overclocking is far from a basic skill and there are multiple things to consider before attempting yourself.
Your basket
Product Name Qty Price Line Total
**B Grade** MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards £139.99
(£116.66) £139.99
(£116.66)
Kingston 120GB SSDNow V+200 Drive SATA 6Gb/s Solid State Hard Drive - (SVP200S37A/120G) £89.99
(£74.99) £89.99
(£74.99)
Western Digital Caviar Red 1TB SATA 6Gb/s 64MB Cache WD10EFRX - OEM HDD £61.99
(£51.66) £61.99
(£51.66)
Seasonic S12II 430W '80 Plus Bronze' Power Supply £49.99
(£41.66) £49.99
(£41.66)
Microsoft Xbox 360 Controller - PC / Xbox 360 (52A-00005) £17.99
(£14.99) £17.99
(£14.99)
* Sub Total : £299.96
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% £371.95
In specification it says
- Graphics Card: Choice of DX11 Compatible Graphics Cards ***OcUK Recommends a minimum of either an AMD 7850 or a Nvidia 660 to play Battlefield optimally at HD resolutions***
