- 2 Feb 2010
- Crowmarsh
I'm after a new mouse as I'm fed up with swapping the cable between work laptop and personal machine. I'd like one with Bluetooth support and a rechargeable battery.
I mean come on, I'm spending nearly £100 on a mouse and it's not even an option??I have a g502 lightspeed and its amazing but costs a lot more than that so.
The G603 seems interesting. Fed up of disconnecting my mouse from my PC to work laptop, so something that supports both wireless and bluetooth is ideal. A bit put off by the extender cable for the wireless dongle. Is reception gonna be bad if I have the dongle in the I/O panel with my case under my desk? Don’t want to buy a wireless mouse only to have wires for it to work properly.
Did you mean the g613? That is one I'm looking at. Seems a bit no frills but seems pretty decent from the reviews.
I have a G603 on order for this exact reason, need it to connect to two devices. I have a G703 currently that I love; hopefully it's the same but with bluetooth too.
That's why I ruled it out. None of the logitech mice do. The corsair ones do though.Looks like the G603 does indeed has Bluetooth:Don't think it has BluetoothThat's why I ruled it out. None of the logitech mice do. The corsair ones do though.
https://www.logitechg.com/en-gb/pro...htspeed-wireless-gaming-mouse.910-005102.html
Just checked there's a like new one from rainforst warehouse for just around £30.04 after the 30% discount.
But looks it use uses AA battery rather than being rechargeable like the G703.
Not saying using battery would be an issue, but was just stating the difference between it and the G703.It lasts for ages however, so not much of an issue IMO. The only problem I see is that it's quite heavy but I'll see how mine is when I get it (plus you can use one battery at a time).
Oh and the G603 does have Bluetooth and traditional wireless; theres a button on the bottom to switch.
may have gone for the 603 then. Oh well, the dark core rgb pro se looks decent at £72. Although I'm paying extra for a load of pointless rgb
Really getting fed up with swapping wires twice a day now![]()
