Watercooled motherboards are cool and something you dont see often but wow 10 USB C and no A thats crazy!
Wouldn't work for me just yet as all my peripherals are USB-A.
Bold move and beautiful board though.![]()
that is a lot of USB C![]()
A monoblock solution would be awesome... given the modern trend of back mounted power connections, they could even move the ports up to the top of the board (and 90/180 degrees rotated) for a totally clean front face (or passthrough like that CPU block that routes water through the moterboard holes with ports on the back)
Word for word was I was thinking of commenting before I posted the RIP USB-A oneHow many USB C's do you need?
me: Yes
Yeah, I would say use your contacts and pressure them to make it happen... but it'd probably cost them several $100k in R&D and they'd sell maybe 100 if they were around £1200 (based on halo tier motherboard plus £3-500 for the waterblock... no idea how much the one you have (will) retail for!), so not worth their while other than to get some hype/exposureIt would be insanely clean! I have both the AMD and Intel version of the Revo tubeless waterblock from Bitspower now so cant test out both setups depending on the build. Though currently the 13700K Blackout build is still my main until i can build the new Valkyrie mod with the AMD 9800x3D.
They certainly be shiny!
Love the clean look and the colour scheme! Is that an integrated pump/res next to the radiator, if so how quiet is it? Was the choice to use the collection of adapters to connect to the monoblock an ascetic choice, or was the space too tight to just run a pair of 90 degree adapters?
That's alright looking I suppose!
Along the lines of Jodie Comer is alright looking!![]()
100% on the industrial look! Can't wait to see it with the waterblock on.
looks really good mate. Very nice clean look
