- 12 Dec 2012
- Milton Keynes , UK
Damn these things always happen when I'm away from home.
Don't worry, there's plenty of work available. As I said before more than 1M wu's.
I am hereby requesting Overclockers UK help on running lasieve5f application for NFS@Home. Sievers are now available for Windows 64-bit.
We are sieving two hard numbers, first one (6,490+) we have left 280k wus, for second number (2,1285-) we have scheduled more than 1M wus.
Thank you in advance,
Carlos Pinho
NFS@Home Moderator
I've put a few cores onto this but can't do too many due to the memory requirements. Can I ask why you are asking for help, I couldn't see anything on your forum about it ?
Asking for help to finish these two numbers as quick as possible so we can start working on harder numbers to justify next year grant of the cluster used for the post-processing stage.
When I can I do like to go to each individual forum and request help. It is a way to approach people to NFS@Home project.
Carlos
Okay, thanks for the info.
Does it run better under Window or Linux ?
Just got 16e now on main pc , had to turn down cpu usage to 60% to stop the waiting for memory messages
andy_taximan,
Not sure if you notice but at this stage G2m1285_ wus only consume 430Mb therefore you can turn up cpu usage to 100%.
Carlos
Andy have you changed the default boinc client memory usage? I think the default is set at only 50% when in use. It's under tools/computer preferences/disk and memory usage.
At current pace 2,1285- will be completely sieved within 100 days.
Keep crunching, we are still far away to finish 2,1285-, more or less 850k wus.
Carlos
