Caporegime
- 18 Oct 2002
- block 16, cell 12
has the time come for SLI'ing PSU's?!
Hell OC3D ran a ti with a RM450.
Thanks for reassurance and kaps post too, not going to ever go more than two cards so I should be fine then, just wondering if a 860i would still be enough for two 780ti's?
Only when the system uses nearly 1800 watts flat out.![]()
Sorry for the slight thread hijack, in terms of tri sli, would the older style gold AX1200 cope? That is my biggest wattage PSU and I was wondering about tri 780s. Bearing in mind the 3930k is often at 5 ghz during benching and the Gpus at near 1.35v when OCed. Would a superflower 1200w plat be necessary or go for a 1500w unit? Or go dual 1000w/1200w like Kaap?
The original AX1200 copes no problem, I had one b4 upgrading to the AX1200i![]()
A very silly video
TTL is a real Noob when it comes to PSUs (by his own admission)
Give me that exact rig he was using, GPUTweak for the card and a copy of Firestrike Extreme or 3dmark Vantage and it will be no problem to get the demand for watts well past 450w.
I have 4770k at 4.4 and 2 780s with evga 1000w platinum, works wonders and have plenty of spare watts. I guess you'd be ok as well.
PSU is just over a year old. Will call ocuk for them to RMA the PSU. Will buy new one before I upgrade. Which one do you have Greg?
It may be a volts thing, I was using around 1.375v with my 290Xs when my 1200i shutdown.
Here is how I solved my problem with the 290Xs.
Wouldn't the SuperFlower 1000 watt be enough?
I also like the EVGA SuperNOVA 1000W 80+ Platinum I think 1200 would be a little too much I'm only going to do small OC's. so if I want colorued cables I'll have to use BitFenix Braided Cables I guess.
EVGA or Superflower?
