Off topic but didnt want to create another thread.
The next step of the process requires me to use the monitor right?
Ive plugged the monitor into the power, works. However I have connected it to motherboard via VGA socket using a VGA cable.
No pciture comes up and monitor is on standby. The monitor is:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-062-AC&groupid=17&catid=949&subcat=
If I press Auto it allows me to choose DVI or D-SUB. Since its not a DVI cable im using a choose D-SUB. But it always says "no signal" and then goes into stanby.
Ive put the CD that contains drivers and onboard manual into the pc but again nothing happens on the screen.
Can anyone help me??
To answer the questions first:
Yes I plugged the aux power into the mobo, it was a 4 pin rather than an 8 pin so i assume that is normal though?
Yes the MSI OC 6850.
Now I tried the HDMI connection on the 6850 on my TV and signal comes through from the PC.
But when I use the mobo's VGA connection on either the monitor or the TV nothing comes through.
BTW monitor supports HDMI and DVI.
TV supports HDMI and VGA.
GPU supports HDMI and DVI.
And mobo does all above.
The only problem is I do not have a DVI cable yet.
Full spec is:
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x OcUK E2250SWDA 22" Widescreen LED Monitor - Black £89.99
1 x MSI HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £82.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £59.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £44.99
1 x Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £43.98
1 x Adata XPG Gaming v1.0 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AX3U1600GC4G9-2G) £38.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £664.81 (includes shipping : £19.10).
