No signal dectected power saving mode on new pc
Sorry i thought this was a fresh drive with nothing on it.
Just noticed you flashed the bios with the CPU installed. You could try removing all the components and flash the bios again with nothing installed except the power cables. (24pin and 8 Pin, not sure if you need the 4 pin as well)
Sorry to be more clear it is a complete fresh drive. I just have a old ssd from my last build with it on.
I flashed the bios twice. I did it once with the CPU installed then later tried it again with nothing but power in. Gave me the same result, past the CPU led and onto the boot.
Good news I got into the bios and chose default settings and im installing windows now. Thanks for the help all, that was a lot more effort that I was expecting. Hopefully its a smooth install from now!
So what was causing the issiue ? Was it your ssd with windows on.
Not quite sure what the actual main problem was but I did everything mentioned. Flashing the bios got me past the first hurdle and then adding the usb with windows on and switching the ram around to the other slots. Windows and everything has installed now.
Edit: That problem I mentioned about the monitor seemed to have sorted itself.
